'87 in an '85
'87 in an '85
I have an '85 Firebird 2.8 with multi-port fuel injection & my engine died. I'm considering buying one out of an '87 Firebird. Is there anything different between these two years? Will I have to change anything extra? Are there any other years/engines that will fit into my car without any major alterations? Thanks!
Welcome to the Boards
An 87 2.8MPFI engine should bolt right in without a problem.
I know some people have upgraded to a 3.4L V6. I think you can use all the 2.8 computers, intake and everything with only a few modifictions. I think there is a tech article about it someplace on this site
Hope this helps
Hope this helps
Transmission: 4L80E/4L80E
It will "bolt in", if you are able to take everything off of the '87 donor car that is needed.
However, it will not "bolt right in". It's not a matter of removing the V6 engine and bolting in the V8 engine. A whole host of things need to be changed, including such items as transmission, radiator, and tach. And, most everything in between.
This is an oft-discussed topic. Look for posts with V6 to V8 in the subject, you'll see a bunch that give all the needed info.
It isn't a very economic option, so unless you plan on providing the labor, you probably shouldn't consider it.
It's a V6 to a V6 - I know that a V8 has too much additional work & money. I'm on a strict budget, or I may have considered it
Thanks for the welcome! I've been lurking here quite a while & I've got lots of help from the board & site.
And I am providing my own labor - my Dad!
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
I believe the only difference between the 85 and 87 2.8s lie within. I think the 87-89 2.8s are intenally balanced where as the 85 will have weights on the flywheel. If you use the flywheel from the 87, it should bolt up with no problems.
