No used parts available in Germany
Car: 1985 IROC-Z28
Engine: TPI 350
Transmission: TH700-R4
Hallo to everybody !
Iīve a TPI-305-IROC with the old 870 ECM. Now I want to swap to a 350. After searching the archives, I think there are 3 things to change : New injectors, a new knocksensor and a new prom. Is this right so far ? - Now, Iīve one big problem : I live in Germany, and I have no possibility to get some parts from the junkyard. That means : 8 new injectors cost about 900 Euro, a new Prom isnīt available ( what Prom can I use ? - A Camaro with the 350-TPI didnīt exist in 1985. Should I use the Corvette-Prom ?? ) The best thing would be a new ECM ... about 500 Euro.
Perhaps I should emigrate ???
What would happen, if I just put the TPI-Setup on the new 350 without changing anything ??
Thanks, Uwe
Thanks, Uwe
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Uwe,
Looks like we've similar problems with buyin' parts... try ebay.com; lots of people there are helpful wiith overseas shipping
Car: 1985 IROC-Z28
Engine: TPI 350
What do you think, is this a good offer : http://cgi.ebay.com/ebaymotors/ws/eB...411546188&rd=1
Try Summit ( www.summitracing.com ) for parts like the injectors. They are very good at shipping things to Europe - just check what the situation is in your country regarding import or value added taxes.
Consider burning your own PROM's etc.
Go on holiday to the USA to buy stuff and bring it home with you.
Good luck with things.
(What would happen, if I just put the TPI-Setup on the new 350 without changing anything ?? )
Nothing, unless you run extremely lean, You could just reuse the 85 305 prom and injectors and knock sensor without any problems, but you should at least get an adjustable Fuel pressure regulator to give the 350 a little more fuel than the 305. (if you dont have access to one of those, shim your regulator). I have done this on one of my 85 TPI cars with a semi worked 350 until I could afford to upgrade the other stuff.
Good Luck!
Good Luck!
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
