Beginning to get together a parts list...
Old Apr 25, 2003 | 11:29 PM
Amrish's Avatar
Has anyone ordered a motor from www.strokermotor.com?
I am planning on getting their 383 but i will have many things changed so it can be well built for supercharging. This is what i need help on.
What 'brand' pistons would you guys recommend as the best? I understand they'd have to be forged as well as the crankshaft.
Are hydraulic rollor cam and lifters the best quality/performance u can get for a cams and lifters? What kind of cam would be required for supercharging and the compression should be around 8:?:1 ? or am i way off?
they also offer packages on top of motors:
Package 1
DES
5140 Forged steel crank, 6.0" I-Beam rod, KB pistons, plasma moly rings, performance bearings, internal balanced
Add
$575.00
Package 2
DES
4340 Forged steel crank, 6.0" I-Beam rod, Lunati pistons, plasma moly rings, performance bearings, internal balanced
Add
$895.00
Package 3
DES
4340 Forged steel crank, 6.0" H-Beam rod, KB pistons, plasma moly rings, performance bearings, internal balanced
Add
$650.00
Package 4
DES
4340 Forged steel crank, 6.0" H-Beam rod, Lunati pistons, plasma moly rings, performance bearings, internal balanced
Add
$900.00
What specifically should i make sure of for a strong supercharged motor? I dont want ANYTHING at all breaking internally...
Oh forgot to mention, this motor will have a miniram on top of it:hail: Wll this change anything?
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
