Need some help
Need some help
OK im not exactly doing a motor swap im putting new bearings in my 83 transam.. Can any one give me step by step instructions on removal?? I have all the vacume hose and gas hoses, throttle cable, a/c, heater, and power steering(pump) off. IM stuck on the wiring i dont want to pull all of it off if i dont have to and if i do do i lable it or can the connectors only go one place? also stuck on bell housing got tourch convertor diconnected but need to get bell housing bolts on top any suggestions??? Thanks for the help and thing will be great !!!
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
most connectors will only go in one spot and the length gives you a clue too, but marking them will definatly tell you where they go. the bolts on top get by going in from the top. i usualy use a normal box end wrench angled away from the firewall.
