Chip for TBI to Carb swap???
Old May 7, 2003 | 02:24 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
I have been reading and it looks like some people have used a new upgraded chip (Thermomaster by Hypertech or a custom made chip) when converting to Carb from TBI or TPI. Can anyone say if this is a must or not. My car seems to be running fine with the stock chip (after all it's only controling the spark now, right? because I bypassed the fuel system). My car kills out at about 2500 PRMs only because I need to ad a bigger fule pump along with the helper pump in the tank (the stock one). Could any of this be due to the fact I need a custom chip made or a hyperformance aftermarket chip? I talked to Brain at TBI CHIPS and he seems to think no, but I wanted other input on the subject (guys who have done this before, carb swap).
GOFASTER
Old May 7, 2003 | 05:59 PM
PhilM's Avatar
Car: Accepting applications...
I will go out on a limb and say this is confusing...why are you still using your computer if you switched to a carb? it shouldn't even be doing anything if the TBI is gone...
Old May 8, 2003 | 12:02 PM
GOFASTER's Avatar
Engine: 388 ci
Well, the computer is still hooked up. Even with the carb swap, you still ust it for gauges and spark control. At least that is the impression I have been under.
Correct me if I am worng, because if I don't need a new chip I am in the money and can move on to other things she still needs.
THANKS
Old May 8, 2003 | 06:04 PM
PhilM's Avatar
so you are still using the factory distributor...the only gauge that should be computer controlled yet is the speedo, but i am not really educated on that aspect. i would loose the factory distributor and tune the thing without the carb.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
NBrehm
Aug 25, 2015 11:49 PM
cstrobel65
Aug 15, 2015 10:19 AM
