305TBI to 383 carb'ed Swap 92 camaro
Old May 21, 2003 | 08:35 AM
gr8ride_71's Avatar
Hey Guys,
I have a few questions concerning a motor swap that will be taking place pretty soon. Its in a 92 camaro and we are swapping the 305 tbi to a carb'ed 383.
What will need to be done/modifications for the transplant? Keeping the stock trans for now. Going to try to use the factory fuel pump , will this work if we use a holley regulator?
Also going to convert this to a v-belt pulley system. Will the powersteering and everything bolt right up or will new brackets need to be purchased? If so which ones?
Old May 22, 2003 | 10:40 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Yes your fuel pump will work if you use a regulator. Are you completely eliminating computer controls? What makes you want to go with the vbelt setup? Personally, I would take the serpentine setup off of that 305 and use it. It's pretty much a direct bolt in after that.
Old May 23, 2003 | 12:44 PM
kdgreen's Avatar
USE THE SERPENTINE SETUP WITH MARCH UNDERDRIVE PULLEYS!
You will hate the v-belt setup. Too much crap that won't line up to worry with. The 305 setup will bolt right up. I removed the smog pump and went to a smaller belt. I ordered the March Crank/Alternator underdrive pulleys. I love my setup. No problems at all.
Old May 23, 2003 | 01:59 PM
stroken_camaro9's Avatar
Car: 92 camaro rs
Transmission: th350
vbelt
well i am already going to use the v-belt setup. i have the alternator and brackets already setup. all i need is a powersteering pump. the block is a 350 from a 78 chevy truck. what should i get that i know will bolt right up for powersteering?
what do u think gr8_ride?
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
armybyrd
Aug 10, 2015 09:23 PM
