Flywheel
Old Jun 8, 2003 | 03:12 PM
Firl's Avatar
Flywheel
I put in my 350 engine this weekend, but when I was switching t he flywheel because It had a manual flywheel on it, and Its going to an automatic, I noticed that the automatic's outer diameter of the flywheel is about a 1/4th of an inch smaller than the old one,
Will this be a Problem at all?
- Firl
Old Jun 8, 2003 | 05:19 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
edit and forget it....
Old Jun 8, 2003 | 07:24 PM
Firl's Avatar
ok when putting the flywheel on, there was a total of 6 bolt position and only 5 of the bolts went in but the 6th was like .001 off so I wasn't able to bolt the last one in, Didnt think that It is a huge deal that one of the 6 were not able to go in.
And to test the starter anyone know a way that I can test the starter unbolted to the engine?
- Firl
Old Jun 10, 2003 | 11:16 AM
Wesdog's Avatar
Car: 85 T/A
Engine: Rebuilding
To test the starter just take it to autozone or somewhere like that. They should have equipment to test your starter i have taken starters to get tested several times best thing is its free and only takes a couple of minutes. Or you could try it yourself off of a battery however i dont think its very safe because the motors are very powerful and could get away from you and tear something up or hurt you.
Be careful
Old Jun 10, 2003 | 01:11 PM
Firl's Avatar
thanks will do that tonight, didn't think of it, I have to go there anyways to pick up the correct flywheel.
- Firl
Old Oct 1, 2003 | 06:12 PM
LucifeR's Avatar
is it just me or did everyone here forget automatics do not have flywheels
automatic = flexplate
manual = flywheel
they are not the same
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
