carb or f.i.
Old Jun 25, 2003 | 10:33 PM
fyrechikyn's Avatar
carb or f.i.
ok heres the deal i need to replace my old 305. im upgradint to a 350 i just dont know what type of induction to use. i like the look and torque of a tpi setup. but i dont like the fact they kinda suck at higher speeds. i want something thats balanced. something with good low end torque but also with a decent higher end. which one would be suited to my needs? a tricked out tpi setup, or a carb setup? id like to know now so i can save up some cash and start pricing what ill need.
Old Jun 26, 2003 | 02:03 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Im no expert but fuel injection
is gonna cost id say 3 times as much..
more parts ...
Easier with carburator & Airgap manifold.
Fuel injection ull need aftermarket throttle body,
runners, TPI base(bigmouth)?
Better chip..
I heard fuel injection doesnt respond well to wild camshafts..
Old Jun 26, 2003 | 11:24 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
If you already have a TPI setup you are better off tricking it out. You can probably get a set of siameased intake runners and a larger throttle body for less than a quadrajunk, intake, and fuel pressure regulator, etc. required for carb conversion. If you are in an emissions state FI is the way to go.
Old Jun 26, 2003 | 04:53 PM
fyrechikyn's Avatar
i only have the sucky tbi. and i live in texas. but im not to worried about passing inspection anyways.
Old Jul 1, 2003 | 01:01 PM
dennis6's Avatar
Car: 1991 Camaro RS
I have the L03, but I am keeping the L03 for now. However I am going carb. You can't do much to TPI to keep it from hitting the 5000 rpm wall. A carb doesn't have that restriction. A TPI setup will cost alot more, something like 700 dollars on ebay for a used complete setup. (TPI, harness, ecm, and distributor)
Stay away from the quadra crap unless you need fuel economy, but then why did you buy a fbody? Get a edelbrock/carter afb if you want it to bolt and go or a holley/demon if you want the best performance possible.
Personally if I was going 350 I would go with a LT1. Otherwise I would keep the L03, swap the heads for LG4/TPI heads, port them out, put in a more agressive cam, higher stall converter, and a weiand 142 blower. I imagine you would be moving at that point.
If you are still running on the 2.73 open rear and stock exhaust, fix them first. I would put sub frame connectors in also.
Old Jul 1, 2003 | 06:02 PM
fyrechikyn's Avatar
im already running headers, no cat, flowmasters, lca's, poly bushings, and sfc's
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
