lt1 vss and 91 camaro speedo
Old Jun 28, 2003 | 10:57 PM
thatsme's Avatar
Do i need to put anything in between the lt1's vss and the speedometer or do they use the same signals? I'm trying to get everything figuered out before i even start putting it in.
Old Jul 1, 2003 | 12:48 AM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
Use the output wire from the LT1 pcm for speedo and hook it directly to your speedo. Works like a charm.
Old Jul 1, 2003 | 12:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you cant just directly connect the two... you would need a converter box..
however, if you have a LT1 installed, i THINK, not positive, that you can splice off the LT1s gauge output and it works..
im learning for my LT1 swap, and this is one of the few things im fuzzy on too...
Old Jul 1, 2003 | 05:36 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
cd90rs is right...just connect the output wire from the PCM of the Lt1 to the gauge input wire(easiest where the original VSS was plugged in at) of the Camaro and it should work fine. It maybe off due to the rear end and/or tire size.
Jorlain
Aug 24, 2022 05:11 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
beachrodder
Aug 7, 2015 04:27 PM
