LO3 to LS1
Old Jun 29, 2003 | 10:08 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
LO3 to LS1
i was just wondering if anyone has done this and how bad it was. im considering doing the swap almost definately within the next year if i can find a donor. also i would like to use a T56 instead of a 4l60E. i have a 700R4 right now
Old Jun 30, 2003 | 02:00 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Now that ppl manufacture and sell motor and tranny mounts it should be a pretty striaght forward swap.
Old Jul 1, 2003 | 03:16 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I was going to go T-56 but I am glad I did not. I have been reading about common problems such as 3/4 shift forks bending. Also, the slave cylinder has a tendancy to stick causing all sorts of headaches.
The 4L60E will be easier on the drivetrains and require less modification as well. Put a good converter in there and you will be good to go.
Old Jul 2, 2003 | 06:11 AM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
how much of a pain was it rewiring your cars for the ls1, ive got a 92 LO3 and am considering doing this swap myself, how much did it cost for the swap, how long did it take, and was all the hassle worth it. Also would i be able to keep my t5 or would i have to get a t56
Old Jul 2, 2003 | 06:37 AM
Engine: LO3 and LT1
how mich modification to the unibody of the car would be needed to handle an LS1. and also the rear end right now my car has a 2.73.
Old Jul 3, 2003 | 02:15 PM
wm_sorg's Avatar
The swap is not cheap, but it is becoming more affordable. Engine, trans mounts, and wiring harness for the swap are available through the aftermarket.
I had Spohn SFCs installed to handle the extra power. If you want to keep the A/C you will have to notch the frame, or use alternative/corvette mounting brackets or some combination thereof.
You will need to switch to a T-56 for this conversion. There is a difference in the input shaft. It may be resolved by installing another shaft. I am not aware if this has been done in the past.
I would recomend going from a 2.73 to a 3.23 rear as I did. Nevertheless, the 10 bolt can not take much abuse under this horsepower. If you are talking track time you need to beef it up or go 12 bolt.
In my opinion it is worth it. YES! The LS1 is 150 LBS lighter than the iron block V8. Others who have done the swap are running high 11's (with mimimal mods), low to mid 12s (stock) while attaing 20+MPG city to 28+ highway, and passing emissions.:hail:
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
