TBI --> Carb...Fan switch?
Old Aug 13, 2003 | 08:50 PM
demonkey36's Avatar
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
As the title suggests, my 91 RS is going from TBI to carb (the post isn't about whether or not I should...I already am) and am wondering about the fan switch.....is the fan switch controlled by the computer right now? and if it is, what do i need to do?
Old Aug 13, 2003 | 09:48 PM
Flyte risk's Avatar
Car: 85 IROC
Engine: tree-oh-five
Transmission: 700, but the T-56 is laying on the floor
I'd suggest reading the "Total Fan Control" article. It will answer all your questions and includes part #'s.
Old Aug 16, 2003 | 05:09 PM
demonkey36's Avatar
Car: 1991 Camaro RS
still a little confused though.....is the fan switch independent of the ECM (running off its own temp sensor or something...) or does it run through the ECM?
Old Aug 16, 2003 | 05:28 PM
Flyte risk's Avatar
Car: 85 IROC
The Hayden switches he refers to run off their own sensor completely independant of the ECM. It sticks between two fins in the upper left corner of the radiator and secuses with the included parts in the kit. I've used the adjustable before on a 4X4 and was more than happy with the results.
Old Aug 16, 2003 | 05:45 PM
demonkey36's Avatar
Car: 1991 Camaro RS
so in that case i'd use the wiring that comes with the kit, or the existing wiring?
Old Aug 16, 2003 | 07:37 PM
Flyte risk's Avatar
Car: 85 IROC
The kit comes as close to wired as you can ask for. IIRC it can be installed in less than 15 min with a pair of wire pliers. It doesn't get much simpler.
Old Aug 16, 2003 | 08:21 PM
demonkey36's Avatar
Car: 1991 Camaro RS
cool. thanks.
BRoss99
Aug 10, 2025 05:08 PM
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
92camaroJoe
Aug 13, 2015 06:07 AM
