TPI to carb, fuel reg help
Car: 87' Iroc
What regulator should I use to bring my 42PSI down to 6-8 so I can use a carb....a link would be great
thnx
thnx
Guest
Posts: n/a
I never actually got as far as installing everything (thanks, Edelcrock), but I purchased a regulator from Mallory (thru Summit). You definitely need a 3 port, one is the return for the return line. If you just get a 2 port it will burn up the pump.
If nobody posts a PN or link, I'll go find my receipt.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: TPI to carb, fuel reg help
thnx
thnx
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 6, 2015 09:03 AM
