L98 TPI to Carb
Old Sep 28, 2003 | 05:08 PM
grissam88TA's Avatar
L98 TPI to Carb
I have a couple of questions. I have a 88TA L98 TPI. I was wanting to go with a carb nice setup. Can I use the block and heads off the L98 or at least the block? Thanks for any help
Old Sep 28, 2003 | 05:29 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
The block I know is fine. It's a 350 2-bolt block. The same block is put in trucks and sold in cheaper crate-engines.
Old Sep 28, 2003 | 10:33 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
of course all that stuff will work its no different than any other small block from the intake down. You'll either need to buy a intake designed for 87-up heads or modify a regular one (much cheaper and very easy to do)
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
matthew911
Aug 12, 2015 09:38 AM
