Emissions and high compression...
Old Sep 29, 2003 | 10:56 PM
StealthElephant's Avatar
Car: 87' Iroc
Someone told me that a higher compression ratio changes certain pollutants. Anyone have any idea? I'm keeping my cat and I have a year until I get reinspected, I'm going to get a new hi flo cat but I'm wondering if I even have any chance of passing.
I'm running about 10.7:1 CR and the Comp cam XE268h....
it's a pretty healthy cam, but nothing over the top....will it be close or should i start saving up my 100$
Old Sep 30, 2003 | 08:19 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
An higher compression ratio, in itself creates higher combustion temps which cause higher NOX production.
EGR lowers peak combustion temps therefore lowering NOX.
So the higher NOX of a high compression motor can be somewhat offset by a higher overlap camshaft which tends to have a built-in EGR effect at low engine speeds. But a rougher idle.
Old Sep 30, 2003 | 10:15 AM
Car: 87' Iroc
my cam has 14 degrees overlap, duel pattern. my buddy said to run regular and i might make it with a really good cat, my emissions is all gone cept for the cat
Old Oct 2, 2003 | 01:34 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
u will most likely have to pay one of the mechanics in the emissions place to lean out the engine while making a run; that is most likely the only way it will pass. what is the lift and duration of your cam?? also if you run a higher octane your emission results will be far better than a lower octane (higher octanes burn more efficently and thoroughly and at higher temps) = less smog
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
sammy52401
Nov 11, 2015 07:20 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
