Vortec Tpi Guys Inside! Need Help Quick
Old Sep 29, 2003 | 11:14 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
I just heard ack from SDPC and they say that the VORTEC TPI intake is not setup for a CSI (cold start injector) ...I have the CSI. Now I have no choice but to get that intake cause my vortecs are already bolted on...Now U guys with the SDPC vortec intake on your car...did u get around the CSI some how. I'm not sure if the L98's came with the CSI or not...but Is there anyone who had the CSI work on their intake? Can I have my PROM burnt to not reconize the CSI and just plug the CSI's inlet on the fuel rail...Please help me out u guys, I want to have this intake ordered on thursday.
Old Sep 30, 2003 | 12:39 PM
cdartz's Avatar
You need to run a PROM from a 1989 model. 1989 was the only year TPI to still use a MAF sensor, but not use a cold start injector. If you remove your cold start injector and don't change your PROM it's not a major problem, but the car will run a bit rough until it warms up on cold days.
Old Sep 30, 2003 | 11:57 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
I'm havin a custom prom burnt, so is there a need to get the 89 PROM...I'm dumb when it comes to this stuff. Also the car will never see a winter day. Is there a way It can be blocked off from the fuel rail?
Old Oct 1, 2003 | 02:21 AM
cdartz's Avatar
So just explain to whoever burns the chip that you'd like them to do it for a 1989 spec car with no cold start valve.
As far as how to plug the fuel rail I can't help you. My buddy John took care of it, and I don't remember what exactly he did, sorry. I'd go look for ya, but I recently moved and the car is stored at a friends house in another state at the moment. It should'nt be that difficult though.
Old Oct 1, 2003 | 05:11 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
you can take off the hard line going to the CSI and just plug it.I got my runners welded shut since it has the CSI.That and the PROM is all you have to worry about
Daz
Old Oct 1, 2003 | 07:59 AM
ZFORCE's Avatar
Car: '87 IROC
Transmission: TH700R4
If you do use an '89 program, be sure that the VATS is disabled. I am not sure if it would cause any problems but there is no need to find out if it would.
tj
Old Oct 1, 2003 | 11:11 AM
Guest
Guest
Posts: n/a
Definitely make sure there is no VATS enabled on there if you run the 89 code.
There is a way to run the earlier chip without the cold start, just a little more difficult to do because its not an obvious thing.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
happyhapka
Aug 15, 2015 04:42 PM
Street Lethal
Aug 14, 2015 08:25 PM
Sanjay
Aug 12, 2015 03:41 PM
