Help, LT1 Swap Problem
Old Oct 11, 2003 | 01:16 AM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
Hey, It's up and running but I have a problem. When I go to accelerate the car seems like it's losing electrical power because i'm hearing the chimes that you hear when you first start the car and the car goes dead and the kicks back in. The numb nuts who wired the car did not ground the PCM . We grounded the PCM and it ran great for a day and now it's doing the same thing except i'm not hearing the chimes. Any ideas ? Thanks
Old Oct 11, 2003 | 07:37 AM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Uh, check to make sure your ground is good? Better yet, check all your grounds. If they forgot to ground the PCM, kinda a no brainer don't you think, then who knows what else they forgot to ground out? Just a thought. I'm not a genius on wiring but at least I know to ground the PCM.....gotta love shoddy worksmanship. good luck
LC
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
