Possibly ZZ4?
Old Nov 19, 2003 | 11:20 AM
SweetRide45's Avatar
Possibly ZZ4?
ZZ4:
http://www.sdpc2000.com/cart.asp?ac...tid=120&pid=117
SuperRam:
http://www.jegs.com/cgi-bin/ncommer...119&prmenbr=361
The only other things I would need would be the injectors and Throttle Body, right? I currently have a '90 Firebird 3.1 mpfi. I'd be converting my loom to TPI (which is only a few splices), and I should be good to go, correct? I'm doing a whole suspension upgrade as well. I'm in IL, and I have to be 100% Emissions Legal, as to why I picked the TPI Crate, b/c I knew TPI w/ the L98 was basically emissions legal. But, from reading, SuperRam w/ the ZZ4 will pass emissions easily. That is just what I wanted to hear. It also says 50 state legal on Jegs site.
Now, my question is, how much power are we talking about w/ that setup? I'd be backing it up w/ a Probuilt Street/Strip 700R4 w/ probably a 2000 Vigilante stall. I also have a BW 9 Bolt Posi w/ 3.27 gears.
My goal is basically 350rwhp. I won't be bringing it on the strip. It will be a Street car. I want to smoke Rustangs, Cobras, LT1's, and hang w/ or possibly beat LS1's on the street.
Thanks for the help!
Old Nov 19, 2003 | 11:24 AM
Here's the updated links:
ZZ4
SuperRAM
Also, would I just need the Plenum and Runners for the SuperRAM? Do I need the base too? Can I use the base that comes WITH the ZZ4?
Thanks again.
Old Nov 19, 2003 | 11:36 AM
Steve89GTA's Avatar
What happened. I thought you were set on the 357HP TPI motor
Old Nov 19, 2003 | 11:43 AM
I "Was"...but reading more posts, it seems the ZZ4 is a better way to go. Well, how about SuperRAM on the TPI engine?
I'd go w/ the TPI Crate if it's the best overall idea.
Old Nov 19, 2003 | 11:50 AM
You might be right Steve. I should just stick w/ the TPI Crate. I've just been thinking about it so long, I'm getting steered in different directions. I keep second guessing all my choices...lol
It's just that I am only going to do this once, and I want the best bang for the buck. The ZZ4 and the TPI are VERY close to the same price...so, just weighing my options.
Old Nov 19, 2003 | 12:38 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
i was doing the same thing before i bought my crate motor. just go with one option, and don't second guess yourself.
LC2 TECH
Oct 13, 2015 11:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
mfp189
Sep 27, 2015 09:25 AM
