Getting ready to build motor for 91'RS
Old Nov 28, 2003 | 01:05 PM
twink_893's Avatar
Hey all,
haven't been here for awhile. got some questions for everyone. my 350 block is now bored .030 over. With my budget of 1500-2000 i now need to get heads, cam, pistons, intake and carb. for the pistons im lookin at KB hyper. cam lookin at comp xe268H. intake i wanna go with the EDDY performer. carb will be EDDY 700. anyone see anything wrong with this combo? also need suggestions for heads. cant really afford alum. right now so im not sure what to use for steel. i will be doing all the motor work myself. i work in a machine shop and have access to machining. i will be able to deck the heads and other little things myslef. thanks in advance for all the help.
Old Nov 28, 2003 | 01:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't say what you're going to have behind this engine, or what the intended use will be.
Regardless, I wouldn't go with that carb. Holley/Demon so much better (despite all the claims about how easy the Performers are to tune - peanuts compared to results). I prefer Weiand intakes to Edelbrock, but that's more a bias than back-to-back comparison data. At any rate, the Performer would probably choke off the cam on the top end. RPM or Stealth would be better.
World S/R Torquers or Sportsman II's would be good iron choices. Or Pro Topline. Since you have machine shop access, port cleanup would be a very good idea.
Hope the budget holds out. Higher end will most likely be the reality.
Old Nov 28, 2003 | 02:15 PM
twink_893's Avatar
Sorry bout that. the car will be used for regular driving but wuld like to smoke the Tangy 5.0's when they pull up next to me and wanna race. would also like to take to the track a couple of times a year but mainly will be driven often in the summer. thanks again for the help
Old Nov 28, 2003 | 11:46 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Pro topline heads. they make more power than the torquers and sportsman 2s are a little large for a DD. I would recommend to 180cc pro toplines.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
jharrison5
Aug 19, 2015 05:53 PM
