Woa, new gmpp 383!
Old Dec 16, 2003 | 11:47 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Woa, new gmpp 383!
I almost fell out of my chair today when I found this. A high performance GMPP ZZ383, equipped with the fast burn cylinder heads, a 4340 forgded crank, and a camshaft that falls below the famous LT4 hotcam on the page (222/230@.050, .509/.528)!! Where did this thing come from?
:hail:
425 horsepower at 5400 RPM, and 460 ft.lbs of torque at 4500 RPM!!! Lets see a dyno curve from this guy already.
Sorry to get all teary-eyed on you fellas, but I have a special place in my heart for performance parts that come straight from the general. I can only imagine this badboy with a ramjet manifold and some dfi running the show. Plenty of strength left over for some forced induction. Hmmmm...insperation.
Old Dec 17, 2003 | 01:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It (or at least a variant http://www.gmgoodwrench.com/perfpart...f/12496769.pdf - "... its Fast Burn cylinder heads are hungry for a little more camshaft, approximately 425 horsepower at 6000 rpm is achievable by adding the HOT cam and 1.6 self aligning rocker arms.") has been around.
Where have you been?
Old Dec 17, 2003 | 06:21 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Kiwi,
what does your 305 combo run at 1/4 mi?
Jari
Old Dec 17, 2003 | 08:17 AM
THE BANDIT-Z's Avatar
Car: 1985 Black IROC-Z
Engine: 305 T.P.I (for now)
Transmission: TH700"R"4 (R for Racing)
SDPC2000.com has this same engine for $4699. I wonder what it would run with a ported tpi setup or a miniram? Anyone?
Old Dec 17, 2003 | 12:00 PM
Car: I
Engine: Taunt
It (or at least a variant http://www.gmgoodwrench.com/perfpar...df/12496769.pdf - "... its Fast Burn cylinder heads are hungry for a little more camshaft, approximately 425 horsepower at 6000 rpm is achievable by adding the HOT cam and 1.6 self aligning rocker arms.") has been around.
Yeah, the fastburn 385, that has been around for a while. That is also a nice peice of equipment, although the ZZ383 adds 33 ci, a hotter cam and a forged 4340 crank to the mix. The quote you put in brings up another question though. The pimped out version of the fb 385 makes the same hp as the ZZ383 using the same heads, smaller displacement and a smaller cam. I wonder what gives here, maybe the ZZ383 is underrated? Like I said before, an independent dyno test of this thing would be very nice to have.
Old Dec 17, 2003 | 03:15 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The ZZ383 has been around for about a year now!
http://www.sdpc2000.com/cart.asp?act...120&pid=156334
Old Dec 18, 2003 | 01:34 AM
five7kid's Avatar
Sorry, I wasn't thinking straight.
The story is pretty much in the peak numbers. The 383 makes the 425 HP @ 5400 with 460 lb-ft @ 4500. The Fastburn/Hotcam 350 needs 6000 RPMs to make the 425 HP, but the torque is still only going to be in the 385-400 lb-ft range @ ~4400.
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
