coolant sensor and oil pressure switch question
Old Jan 14, 2004 | 05:27 PM
RedRS90's Avatar
hey I have a question I have a block from the mid 70's and I need a coolant temp switch/sender"goes on the bottom passenger side of the block" and an oil pressure switch "goes on the driver side of the block above the oil filter". I dont know where to get these, cuz the guy at autozone couldnt find the right coolant temp switch/sender and when I got the oil pressure switch, it hooked up the way it should but it looked smaller than the stock one, and the part that was supposed to thread into the block is to big for the hole thats there.....what am I supposed to get, or does anyone know what I should do,they are for my 88 tpi system thats going on my car
Old Jan 14, 2004 | 09:32 PM
RedRS90's Avatar
come on, anybody?
Old Jan 17, 2004 | 10:53 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Pop open a summit catalog and order the sending units from there. Alot easier than trying to tell the dummys at Azone that you have a 70's engine in an 80's car.
Old Jan 18, 2004 | 01:02 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The one on the passenger side of the block, near the starter is the knock sensor.
The coolant sensor for the gauge goes into the driver side head, and the one for the fan switch goes into the pass side head.
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
ChevyZ71
Aug 13, 2015 07:30 AM
92camaroJoe
Aug 13, 2015 06:07 AM
