TBI to 383 carbed swap
Old Jan 16, 2004 | 10:12 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Which sensors to use???
I have an 89 RS with the TBI 305. I am building a carbed 383 to replace the old 305. I was wondering how much of the sensors and gadgets i will need to keep plugged in to the wiring harness. I am removing the air conditiong system and the smog pump. So how much of my wiring harness will i still need to keep hooked up? If it makes a difference i am using the 89 700R4 that came with the car.
Old Jan 31, 2004 | 02:41 AM
1fast91rs's Avatar
Car: 1991 RS
Engine: 305 LO3(TBI)
Transmission: TH-700R4
i would also like to know if anyone has any input
Old Jan 31, 2004 | 02:50 PM
PhilM's Avatar
Car: Accepting applications...
basically there are two harnesses, one from the passenger side and one from the driver side. they are mixed together, so you will need to trace everything and seperate. the passenger harness is your ECM, and it can go bye bye along with the sensors attached to it. when finished you will have your starter wires, alternator wires, and igniton wires out of the driver side harness left. I did this myself, and it only took a few hours to go through it all, seperate, remove, and rewrap...i may have some photos...
Old Feb 1, 2004 | 05:53 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Yeah, im droppin a ZZ4 in soon, carbed, so i need to remove the harness also, any help would be good, thanx
Old Mar 1, 2004 | 06:35 PM
weberusn's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I too, am thinking of going carbed. So if you could post what to do any help would be great.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
tero
Aug 15, 2015 02:47 PM
cstrobel65
Aug 15, 2015 10:19 AM
tero
Aug 6, 2015 06:34 PM
