looking for some egr info from the lt1 swappers
Old Feb 6, 2004 | 05:05 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
What did you do with the egr when you put headers on?
thanks.
Old Feb 6, 2004 | 07:36 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Do you mean A.I.R.?
Old Feb 7, 2004 | 06:01 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
i dunno.. I guess so.. since im getting rid of all that crap.. there is an egr valve on the back of the intake and some other thing which is to the right of the egr and once went to the manifolds.. (never to go back).. just wondering how you handled that hole / egr.. not exactly sure what A I R is ....
thanks.
Old Feb 7, 2004 | 07:56 AM
LT1swapper's Avatar
EGR Tube to Header interface
If you are serious about hooking up your EGR to your headers, give Al at Stainlessworks a call, they should have a part available for this very soon.
www.stainlessworks.net
Old Feb 7, 2004 | 08:14 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
the only way i am hooking the egr back up.. is if i have too If I don't.. I will have to make some block off plates.. but I will have to trick the computer some how, won't I?
Old Feb 7, 2004 | 11:51 AM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
you just have to block the square hole where the EGR valve went. If you leave the solenoid valve for the egr valve hooked up it wont give a code. You can replace the solenoid valve with a resistor if you want to get rid of it too.
If anyone is in the Augusta georgia area and needs LT1 OBD1 PCM work done let me know, i can shut off the EGR and stuff like that so you wont need a resistor or anything. VATS, CAG, AIR disable no problem.
Old Feb 7, 2004 | 12:50 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
If youre interested in a set of blockoff plates, drop me an email.
92firebirdguy
Sep 1, 2016 07:53 AM
L0tuS
Oct 4, 2015 08:07 AM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
L0tuS
Sep 4, 2015 11:16 PM
