pistons
Old Feb 21, 2004 | 09:09 PM
harryo's Avatar
Car: 1989 chevy trk4x4,1994Z28
Engine: 307to400 (colector)
pistons
desides visual whats the difference & purpose between 2 vr & 4 vr
Old Feb 21, 2004 | 10:06 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
compression and price.
4vr you can use 8 identical.
2vr you have to have 4 and 4 (they have to go in only one way, dot forward)
4vr will lower compression over 2 vr.
Old Feb 22, 2004 | 11:31 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Not really. Most 4 valve relief pistons are 4 to 6cc's
5cc being very common. Most 2 valve relief and single trough type relief pistons are 5 to 7cc's.
Some have different compression heights.
(how far down in the bore the piston top is at TDC)
Old Feb 22, 2004 | 06:31 PM
Deck height varies yes, and I didn't state that those are the only differences.
We are both right.
I see what you mean about the 2vr having similar cc, one would assume to be to keep compression the same but allow for a higher valve lift.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
