LT1 Swap, LT1 PS Pump questions.
Old Mar 5, 2004 | 12:45 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Will the PS pump from a 4th gen work.. no probs except the lines? A little concerned.. 4th gen had a rack.. .. and im going over budget quick... but what else is new...
Old Mar 5, 2004 | 12:52 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Jeez man, you should have put this all in one topic, a lot of this is already discussed in many topics, the fourth gen P/S is used, you need to buy a reservoir for a fourth gen because the reservoir is not located on the pump, I bought one from a 98 V6 3.8 firebird. You will have to make some custom hoses.
Old Mar 5, 2004 | 02:54 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
your a fountain of knowledge... :hail:
i find it hard to search for somethings because you can only put in 3 char or more.. AC, PS don't work..
nonetheless... thanks again..
Old Mar 5, 2004 | 06:02 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
You won't necessarily have to make custom hoses but it probably will be neater. I used the stock '94 Vette p/s hose and it fits perfectly but it could be about 2-3" shorter. I'm sure there is a GM p/s hose that will work perfectly it's just no one has stumbled accross it yet.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
