385 fastburn crate motor ??
Old Mar 9, 2004 | 10:35 AM
Flyersman29's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
http://www.sdpc2000.com/cart.asp?act...1578&pid=2598#
i'm toyin with the idea of gettin the 385 fastburn with the LT4 hotcam... except i plan on using an HSR and an hsr won't bolt up to the fastburn heads... is it relatively easy to just swap some afr 195cc heads on there and swap the rockers and springs over? or would i just be better off getting a 350 crate and doin cam and heads myself?
thanks
Old Mar 9, 2004 | 11:06 AM
eric m 91 rs's Avatar
i would say get the block and do the heads, cam, and intake yourself.....i mean if your gonna swap all that $#!+ out anyway then what are you paying 5k for? a 385 bottom end and some spare parts on top of the fact of however much its going to cost you for the afr's and stealth ram. for the 5+ thousand you would spend on the fastburn you could easily build a stronger faster engine for less. just my 2 pennies
Old Mar 9, 2004 | 11:13 AM
yeah thats kinda what i was thinking... what other intake options are there with the fastburn heads?
Old Mar 9, 2004 | 11:56 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
TPIS can get 450hp with fast burns, thier ZZ9 cam and miniram intake.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
masonta
Aug 31, 2015 10:14 PM
