350 crate engine
Old Mar 16, 2004 | 03:50 PM
zapr's Avatar
Car: 1985 camaro z28
Engine: 305 lg4
350 crate engine
........Hey everybody.........I'm new to this forum. This is my first post. I have an 85 z28 with an lg4 305. I'm thinking of the 350/330hp deluxe crate engine. My question is, will there be enough hood clearance with the carb and intake on the deluxe engine? What e.ts. can I expect with the 700r4 trans. and 3.23s and will the unibody handle it? Is there anything else I should know? Thanks in advance..........Zapr.
Old Mar 16, 2004 | 11:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
It's been done by several. Mr. Search Button will aid you in discovering their experiences.
There will be "issues". You'll need a drop-base air cleaner to fit under the hood, but that's not a biggie. The chassis needs subframe connectors (a V6 3rd gen needs subframe connectors). The exhaust currently on the car should go where it deserves to be - the recycle bin - all of it.
You might consider the base HO engine, get a Vortec q-jet intake, and use the rest of the LG4 induction and controls - would make for a good daily driver with some nice grunt. But, I'm extremely biased in that respect.
Low 14's to high 13's can be expected with slightly higher stall and some traction.
theshackle
Sep 17, 2020 08:26 AM
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
