LT1 question
Old Mar 19, 2004 | 07:42 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
LT1 question
can i put LT1 heads and intake on an older engine block? (pre-'86)
im asking because i am not sure about the water pump mounting to the block since the coolant holes are different on a normal water pump and an LT1 water pump....
any help will help me out a ton!, i wanna get this swap done as soon as possible, and i got alotta work ahead of me,
thanks,
keith
Old Mar 19, 2004 | 08:10 PM
yamahaguy91's Avatar
Car: 88 camaro RS
Engine: that thing under the hood?
Transmission: a what????
no
Old Mar 19, 2004 | 08:32 PM
TexasLT1's Avatar
Car: '92 RS
Yes you can, but you really have to ask yourself why. The work involved is fairly substantial, plus you have to drill the intake for a distributor. The better solution is to keep the traditional SBC heads and get a modified LT1 intake.
Just thought of something, what does the water pump have to do with anything?
Old Mar 21, 2004 | 12:09 PM
Car: 91 camaro rs
LT1 swap ?'s
okay, i wasnt aware of the distributor issue when using the older block with the LT1 intake,
but as far as the water pump, i was asking because, the coolant holes on the front of the LT1 block (correct me if im wrong) are different then an earlier block, and also i didnt know if the reverse cooling aspect of the heads, and the waterpump being cam driven, would affect anything..??
thanks for the help
Keith
Old Mar 21, 2004 | 01:20 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
http://www.lt1intake.com
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
