more lt1 swap woes.. -VATS in 89
Old Apr 6, 2004 | 09:10 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I have VATS in my 89.. I am getting rid of it in the 94pcm.. I have a wire coming out of the PCM labled "Fuel Enable signal" its 2.5V DC in key on & run. It is supposed to go to the 94 VATS module. .. I am a little lost as to where this should go.. I assume its needed to tell the vats to turn the pump on.. Is the VATS on the 89 comparable to the 94 in this regard? 2.5V is a bit tricky to reproduce.. .. anyone??
thanks. yet again..
without thirdgen.org .. id be up s&*^ creek .. This place rocks..
:rockon: thanks everyone for the help with everything!!!
Old Apr 6, 2004 | 09:28 PM
TexasLT1's Avatar
Car: '92 RS
Yes, the modules are the exact same. Just put the wire coming from the '94 PCM into the fuel enable pin on the VATs module for the '89 location.
Old Apr 7, 2004 | 11:36 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
that's a relief.. thanks..
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
