swapping lt1 into 83 with crossfire injection
Old Apr 26, 2004 | 01:34 PM
kbog54's Avatar
Car: 1983 Z-28
Engine: 305 CFI
Will there be any problems swapping an lt1 into a 83 z 28 with a 305 cfi? I also want to swap in the auto tranny.
Old Apr 26, 2004 | 01:59 PM
kevinc's Avatar
Car: 1982 Z28
Re: swapping lt1 into 83 with crossfire injection
Nothing big I suspect, I upgraded my CFI car to TPI and again recently to an LS1.
If your car had a TH200C trans (3-speed auto), you'll need to either use an aftermarket trans crossmember, or drill the two rearward holes for the stock crossmember. The TH200C is quite a bit shorter than TH700R4 or 4L60E trannies, and the frame holes for the crossmember are farther forward.
Old Apr 27, 2004 | 01:19 PM
kbog54's Avatar
Car: 1983 Z-28
Engine: 305 CFI
nope, my tranny is the 700r4 with overdrive.
Old Apr 27, 2004 | 02:32 PM
kevinc's Avatar
Car: 1982 Z28
Good deal, that was the only headache w/ my swap. The rest is pretty cookie-cutter type stuff, the wiring is no more of a hassle on a CFI car than the other models.
Old Apr 28, 2004 | 10:27 AM
kbog54's Avatar
Car: 1983 Z-28
Engine: 305 CFI
did you have any problems sticking that ls1 in? I was considering that route, but i dont think i can afford it right now.
Old Apr 28, 2004 | 09:50 PM
kevinc's Avatar
Car: 1982 Z28
Nope, it dropped right onto the Spohn engine mounts I installed. Wiring was no more painful than the previous TPI swap. Gauges are a minor hassle w/ the LS1...coolant temp is incorrect, tach is way off, no cable-drive speedo.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
3tas4me
Sep 4, 2015 01:45 PM
sreZ28
Aug 14, 2015 07:48 PM
