305 bore it out...is it worth it??
Old May 2, 2004 | 02:57 AM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
Hey jw what I could expect for displacment if I were to bore out my 305....and would it even be worth it, or should I just look for a good solid 350 and work on that?.....Im thinking Im gonna hear the obvious answer here....
Old May 2, 2004 | 06:21 AM
ljnowell's Avatar
get a 350
Old May 2, 2004 | 06:57 AM
ede's Avatar
ede
you don't over bore to increase displacment you do it to clean up the holes. +.030 would make 310 CID
Old May 3, 2004 | 12:02 PM
Drakar's Avatar
Re: 305 bore it out...is it worth it??
This is one of the fabled "buy a 350" questions.
no arrgument, just get one and be done.
Old May 5, 2004 | 04:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
350 is easier to find parts for, they are cheaper to buy/build and will make more power. Do the 350, you won't regret it.
Old May 10, 2004 | 09:54 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Engine swap from 305
I have a 305 that runs real good and strong however it has over 100,000 miles and leaks oil in two or three places from underneath. I have spent $1500 on the trans and just spent $700 on the front end. Shifts and handles great! I would like to continue the work and eliminate the leaks which I assume would mean pulling the engine. (Its more than a leaking oil pan)
How much should I expect to pay to have the 305 pulled and rebuilt and also have the 305 pulled and changed to a 350.
Appreciate your feedback
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
neekolzun
Aug 24, 2015 04:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
rithsleeper
Aug 11, 2015 07:55 AM
