xe268h ?? any remarks?
Old May 5, 2004 | 06:14 PM
Blkdth87's Avatar
Car: 1989 TRANS AM
Engine: 2004 GTO LS1
Axle/Gears: 02 ws6 torsen diff 3:42
hey, i got a 350 stock bore 81 block, 4 bolt main
dart pro 1 heads 2.05 1.60 valves 64cc
keith black pistons w/ 2 vr est cr 10.3 to 1
scat forged rods and 9000 series crank
full edelbrock intake w/ runners ported plenum and 58mmtb
24lb injectors w/ afpr
ram air hood w/ intake box
got the stuff to program the computer
currently looking at the xe268h cam ???
what do u guys think? should i go w/ something different?
i don't have a hydraulic roller block, so i'm using a flat tappet hydraulic.
any ideas for cam selection would be appreciated.
i have a 2400-2700 stall convertor, w/ 700r/4 perf build
3 series gears in the 9 bolt.... looking for something streetable w/ decent idle and the ablility to run somewheres in the 12sec range in the 1/4 (hey wouldn't mind better though)
Old May 10, 2004 | 12:13 AM
Blkdth87's Avatar
Car: 1989 TRANS AM
anybody????
do u guys think this is a good cam to pick w/ my setup, or should i go more/less radical????
Old May 10, 2004 | 12:52 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I would try something with at least a 112 Lsa, for tuning.
Look here you will see extreme energy, hydraulic flat tappet, computer controlled engines, any with at least 112 LSA.
Kevin
Old May 10, 2004 | 02:39 PM
StealthElephant's Avatar
Car: 87' Iroc
I've got it, it's a pretty tame cam, I would probably have gone 274 if I had the chance to do it over again.
Old May 10, 2004 | 04:05 PM
Blkdth87's Avatar
Car: 1989 TRANS AM
what are the specs on the 274??
anyone using any other brand of camshaft??
i'm running out of time got about a week left before i'm gonna need the cam, my rotating assbly is going to get balanced tommarow.......
RedLeader289
Sep 23, 2015 06:50 AM
bhaas
Mar 9, 2002 08:36 AM
wiggy'sIROC
Feb 14, 2001 07:08 PM
bhaas
Jan 4, 2001 01:30 PM
