Witch motor?
Old Jul 11, 2004 | 10:00 AM
Nikon02's Avatar
Car: 86 iroc
Engine: crappy 350 crate i am building up
Witch motor?
i have recieved am 87 iroc that me and my dad have taken the old motor out and put in a crate 350. is there any way i can find out which motor we put in so i can try to get some specs on it.
Old Jul 11, 2004 | 10:16 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Checking the casting number could help a bit .. www.mortec.com
I dont understand how you can have a crate engine and not know where its from ??
Dont you have paper work, or a decription ?
anyhow, check the # , it should give you a clue
Old Jul 11, 2004 | 03:07 PM
Nikon02's Avatar
Car: 86 iroc
its from gm but i dont know witch motor it is. i guess i needed to have made that clearer.
i know it is a 350. i know it runs really well compared to the lt1s.
i was just tryin to find out if there is anything on it to find a serial number or somthing to look it up online and get some specs for it.
Old Jul 11, 2004 | 04:44 PM
Spectre's Avatar
Engine: 3.0L/183
there are casting numbers on the block, and heads..
that should give you an idea.. tho the cam and internals,
i dont see how you can identify them..
maybe the seller could give you some info ..
Old Jul 18, 2004 | 01:23 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
That's the one the lady on the broom uses
It's Which... What's happened to the schools these days, sorry for the rant but I go to a lot of forum's and this one has the worst spelling I have ever seen!!!
You should be able to do a Google with the numbers you get off the engine and find out what it is.
Old Jul 18, 2004 | 07:12 PM
Nikon02's Avatar
Car: 86 iroc
it was done for fun there bud. i admit that i went to a bad school but i think i knew WITCH way i spelled it.
Old Jul 18, 2004 | 07:24 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Get the one with the biggest broom! They go the fastest!!
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
inferno15
Aug 29, 2015 01:48 AM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
