96' LT1 - O2 Sensors?
Old Jul 19, 2004 | 06:29 PM
darkangrydragon's Avatar
Hi all!
I am currently working on dropping an LT1 from a '96 caprice into my '90 firebird (LO3). I've got the engine wiring harness from the caprice.
The '96 LT1 has 4 oxygen sensors. I am planning on converting to OBDI, but I want to know if it is possible to keep my Hooker shorty headers and catback. Right now they only have one O2 bung (I think in the Y-pipe). Is this possible? Can you delete one of the pre-cat O2's from the PCM? If not, what are my options.
Thanks!
-Andrew
PS: Sorry if this has been asked b4, but can't search for O2 since len("O2") < 3....
Old Jul 19, 2004 | 07:47 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
OBD1 is 2 O2 sensors
OBD2 is 4
u keep the ones that go in the manifolds. or headers.. ditch the ones that go around the cat.
if you have only 1 hole in the y pipe.. you can easily fill it in and get 2 bungs.. or 18x1.25 nuts and get exhaust shop to put em in the headers at the collector.. thats what i did. and i did swap in garage.. and pluged the 2 o2 in but left em under the hood hanging.. (careful they are heated) .. and went to town.. got muffler sho to put em in. i have hedman headers but im sure its the same.
Old Jul 19, 2004 | 08:11 PM
that's what I figured I'd have to do. Oh well. Once I go to odbI I will have the 2 O2's after the cat(s) deleted. I haven't dropped the engine in yet, so I think I will just take the headers to the shop and have them do it off the engine.
Thanks for the advice, Thirim!
Old Jul 19, 2004 | 10:13 PM
Drakar's Avatar
I am doing basically the same thing, 96 Roadmaster engine into my 85 and converted to 95 Z28 PCM programming (OBDI), I have hooker shorties 2055 with only 1 bung so I had the other put onto the very top of the other y-pipe ill grab a pic in a few days.
Easier to install into y-pipe then collector, less meterial for them to go through and less to screw up .... had mine instead for 40 CAN$
Old Jul 20, 2004 | 06:24 AM
Good tip Drakar, thanks!
A pic would be awesome! I'll print it out and bring it to the shop so they know exactly what to do!
I have the 2055's too!
anesthes
42
Oct 24, 2015 07:30 PM
77z
Apr 9, 2002 11:40 AM
redtail2426
Feb 6, 2002 08:18 AM
88TPI406GTA
Jan 9, 2002 09:44 PM
MTVette
Aug 15, 2001 11:35 AM
