Guys who use Vortec heads...question.
Old Jul 23, 2004 | 06:21 PM
StealthElephant's Avatar
Car: 87' Iroc
http://www.pickproparts.com/PartsLis...ategoryID=5424
I used that intake manifold gasket. It's expensive, and I can't get it anymore from my local shop.
http://store.summitracing.com/partde...FPP-1255&N=120 300569
That is what summit carries. Does it matter? The one I originally used was like 35$ when I got it from pep boys. Will the one summit has be just as good?
Old Jul 25, 2004 | 03:11 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The felpro 1255 will be fine. It's nice and thick.
If you want to be able to reuse it a few times, coat it with white grease during installation.
Will require a retorque after a few heat, cold cycles.
Old Jul 25, 2004 | 03:35 PM
Car: 87' Iroc
I ended up driving to a bigger pep boys and got the more expensive gasket (the first link). Does that need to be retorqued as well?
Old Jul 29, 2004 | 09:51 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
i use the stock vortec gaskets.. they work just fine, the ports are teh right shape, the right size, the holes for the bolts are in the right spots. they have the right thickness so the intake doesnt' "fall in"
you just have to torque them properly.. only about 11-14lbs.. that's IT. no retorqueing required.
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
Street Lethal
Aug 14, 2015 08:25 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
