wat can be done to make a Lg4 run at least 14's ?
Old Sep 3, 2004 | 05:13 PM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
ive been wondering what combos can be done to a 190 hp lg4 to make it run atleast 14's without sprays or turbo?
Old Sep 3, 2004 | 05:24 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
LT1, ZZ4 and such camshaft
Matching springs
L98 heads
Roller rockers
Lower gears (3.55-3.73-4.10) posi of course
Better intake manifold
Rebuild Q-jet carburator
Good tires
Car is obviously in good shape, right ?
:edit: you need a flat tappet camshaft.
something like betweem 200-210@50 intake 210-220 exhaust
Old Sep 4, 2004 | 04:35 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Your 84 LG4 is only rated for 145 or 150 HP, with something like 8.3:1 compression. Same as the one I run:
Stock heads.
Stock intake (cast iron to boot).
DR or DG secondary metering rods in the stock Q-jet.
Stock ignition.
Stock 3.42 rear gears.
Stock peg-leg differential.
Worn-out BFG T/A radials.
Small .420" lift camshaft.
Hedman headers and Y-pipe
Dynomax 2 3/4" catback.
T5.
225,000 miles on engine.
Best ET: 14.49
Best MPH: 98.7
Old Sep 5, 2004 | 08:45 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Do not use L98 heads. They have larger chambers that will only lower your already low compression. You should have 416 casting heads. They flow just about as well as the L98's and respond well to porting. The most important thing you could do besides a tune-up is replace every part of the stock exhaust. Headers, high flow cat, Y- pipe, muffler. Don't get it for and LG4 either. Get it for an L98.
Old Sep 7, 2004 | 02:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Here's one such combo in sig (assuming sea level, and assuming the 2-3 shift problem was cured).
Daily driven, emissions-legal.
Would be even quicker with more stall and more gear.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Jae992
Aug 27, 2015 09:07 AM
355tpipickup
Aug 19, 2015 10:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
