LT1 Fit On 700R4
Old Sep 22, 2004 | 01:59 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
LT1 Fit On 700R4
i got a 87 iroc with a 305 TPI automatic and i wanted to know if i could drop a lt1 with keeping the stock tranny?
Old Sep 22, 2004 | 02:44 PM
Drakar's Avatar
Re: LT1 Fit On 700R4
yes, but you need a 93 throttle body, so you can hook up your tranny, otherwise it is a straight swap.
Old Sep 22, 2004 | 02:51 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
so all i would need is just a newer manifold and tb to make it work
Old Sep 22, 2004 | 04:09 PM
Drakar's Avatar
no if your talking about an LT1 like the Gen II LT1 you only need a 93 TB to make your 700 work with it .... you need all the usual swap items for droping an LT1 into a 3rdgen, which there are plenty of lists all over, Im actuall finishing up my swap and there are many others that have, so just do some searchs and then what ever questions you have we can answer.
Old Sep 22, 2004 | 07:11 PM
TexasLT1's Avatar
Car: '92 RS
do people know what a search is?
Old Sep 22, 2004 | 08:20 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You need a throttle body from a 93 camaro / firebird with LT1, you also need the TV cable from the same vehicle, the IAC housing from your 94+ body will swap onto the 93 body to keep you from having to change wiring since the connector for the iac is different, and apparently the VSS from an auto 4th gen will bolt right into the 700R4 eliminating the vss pulse difference issue.
Old Sep 22, 2004 | 09:36 PM
TexasLT1's Avatar
Car: '92 RS
Interesting. Still no easy solution for a T-5?
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
anesthes
42
Oct 24, 2015 07:30 PM
C409
Sep 1, 2015 03:42 PM
midge54
Aug 29, 2015 09:51 PM
