MSD gear, what gains expected?
Old Oct 28, 2004 | 02:01 AM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
I am putting full msd gear (6A , Distributor, 8.55 wires ) on my crate 350 to ensure the "crispness" and to pull a little harder/ But what kind of gains can i acutally expect with this setup? My crate is a 350 which is dynoed at 360 hp / 380 ft lbs at the flywheel Im switchin over from tbi and running a 670cfm carb on top of a edelbrock per. rpm manifold. Cant remember cam specs of the top of my head. I tried searchin but nothing like this really came up. Thanks yall
Old Oct 28, 2004 | 05:02 AM
ede's Avatar
ede
if you have a good working ignition now i doubt you see any gains from going to msd parts.
Old Oct 28, 2004 | 06:38 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Been there done this. If your current ignition is upto snuff, there will be absolutily no gain. But now you can start to easily add electronic goodies like 2 steps, timing retards, etc...
Old Oct 28, 2004 | 06:49 AM
sean86sc's Avatar
Car: 86 camaro sport coupe
Engine: 355
Been there done that too. It is one of those mods that won't gain you much of anything, but sets you up to be able to handle more mods like nitrous, blower, or anything that gives higher cylinder pressure. What I noticed with mine was easier starting and better throttle response.
Old Oct 28, 2004 | 10:55 AM
OutLaw305's Avatar
that sounds good to me. thnx guys
GTAman
Jul 3, 2024 07:29 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
