LT1 Swap finished!!!!
Old Nov 20, 2004 | 08:33 PM
Drakar's Avatar
5 and a half lazy months and its finished, she fired up and idle very smooth for having only open headers
turns out bad injectors was my problem so I got another set coming this week.
Big Thanks go out to TexasLT1, Pasky, Z28R1cer, Thirim, and everybody else.
Only things left for me to look after are the little things.
Which is also my question, need ideas on mounting the PS reservior.
Old Nov 20, 2004 | 09:15 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Check out the newer 3800 cars for their resivoir, its different than the LT1 piece and has a metal bracket.
Old Nov 20, 2004 | 10:17 PM
pwmin's Avatar
Car: 86 Camaro
Engine: 350: vortec heads, lt1 block
Transmission: TH700R4: Mr. Shift kit
pics?
Old Nov 20, 2004 | 11:06 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I used a 3800 power steering reservoir and mounted it where a v6 battery or in the case of v8s, charchoal canister is. I have the hoses going along my wonder bar up to the side of the radiator. I just cut two notches in the bracket to bend the bracket at a 90* angle.
Old Nov 20, 2004 | 11:09 PM
pasky's Avatar
The area is more cleaned up now and that hose coming from the steering box now goes underneath.
Old Nov 21, 2004 | 12:21 AM
TexasLT1's Avatar
Car: '92 RS
Dang, wish I would have known about that when I did my swap....oh well. Glad to hear you've got it finished.
Old Nov 21, 2004 | 02:04 PM
Drakar's Avatar
Ill have to grab one of those, so it's the V6 Bracket? and res? or just the bracket.
and it looks like enough room for my PCM as well, as it will sit where the charcoal canister was.
Also this LT1 swap has also confirmed/completed an LS1 Plastic tank install as well.!!!
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
