Power Steering Pump On 350?
Old Jan 3, 2005 | 09:21 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
Will the power steering pump mount on any chevy 350? if not what year block will i have to look for i ahve a realy good deal ona 450hp 350 and i decided to keep the power steering will it wotk?
Old Jan 3, 2005 | 10:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yep. As long as the heads have front accessory bolt holes, you will be fine.
Yes it will work. Power output does not matter as far as will power steering work. Unlike brakes that are vacuum assisted, the power steering, is belt driven. So as long as the engine is turning, you will be fine.
Old Jan 4, 2005 | 09:00 PM
Car: 87 Formula
Engine: 350 tpi
ok thanks do most aftermarket heads have the accessory holes?
Old Jan 4, 2005 | 11:04 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
More do than don't (most that I have seen do). Just look and see if it says something along the lines of "ends drilled and tapped for front accessories."
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
theshackle
Mar 5, 2017 06:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
