swapping carb for tpi
Old Jan 18, 2005 | 03:17 PM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
i had a 305 tpi and was racing at the closest drag strip and though i blew a head gasket. the next i get the heads off and find it to be a cracked piston and cracked block. now i am preparing to carb my 350 i'm putting in. is this a mistake or should i go the way i'm going. i know thw cam i have is to big for the computer to adjust for it. but should i have spent the money for a computer to be programed or just stay with the carb. and yes i know mpg will be less. any incite is apperciate.
Old Jan 18, 2005 | 11:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
We normally don't like to see incite on the board, but perhaps we can provide some insight...
The EFI vs. carb decision really has to be based on primary use, or to put it another why, what is most important to you. If fuel economy, emissions, and general daily driving manners are primary, stay with TPI. If all-out drag strip performance is more important, go carb.
Whichever you decide, you have to design a "package". The cam is part of that package. The one you would get for carb is most likely going to be different than the best one to get for TPI.
As for the computer, get the equipment and do your own PROM tuning. There's a forum on the board dedicated just to that process.
Old Feb 5, 2005 | 06:30 PM
i just trying to get the car done quick and i keep running it to problems and i was just wondering if its worth going through with it
Old Feb 5, 2005 | 06:54 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
go carb
Old Feb 6, 2005 | 03:07 AM
contactpatch's Avatar
Engine: sbc 350
87',
the advantage to carb is:, you choose any intake manifold
you want.
With TPI, you are stuck {mostly} with GM's TPI manifold,
that has restrictive small air passages.
Old Feb 6, 2005 | 09:49 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i am a carb guy, but have always wanted to tinker with FI. there are plenty of aftermarket parts to get that tpi to flow well. runners and upper/lower intakes. Accel has the superram, edelbrock has stuff, and so does SLP.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
