v6 to v8
Car: 86 Camaro
Engine: 2.8L MPFI
Transmission: 700-R4
v6 to v8
Found the sticky helopful but does anyone havea site or a tutorial/their build up process of a v6 to say a 350 4 bolt main? I think because this v6 is toast and I can't figure out what is wrong, I may just do the 350 swap anyways. I have tired searching,c an't find anything really helpful yet
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Motor mounts need to the front, new tranny, new gauge cluster. Thats it. Everything else is the same. You'll just have to route your A/C and power steering custom.
Transmission: 4L80E/4L80E
With the exception of what's different between a V6 and V8 car/engine, it's a matter of doing the engine pull properly by labelling everything as you go, and then changing what's V6-unique in the car to the required V8 stuff. Take pictures before you start and as you go. The typical Haynes-type shop manual is good enough for the step-by-step of the removal and install.
If you get 3rd gen V8 accessories and brackets, you don't have to custom anything. I pulled the entire AC system out of each car without opening up the system, so even that didn't require anything unusual.
The sticky tells the rest. I tried to make it as chronological as I could, but didn't intend it to be step-by-step.
It's hard to beat a V6 to V8 swap when it comes to learning what these cars are made of.
Car: 86 Camaro
Engine: 2.8L MPFI
Well just for the sake of thirdgen.org I'm going to do a step-by-step pictures included wherever possible of a v6 to v8 swap to help anyone else who does this project, not to mention the extreme documentation that will be on my site about it.
I will keep everyone posted.
