400 sbc
Old Feb 10, 2005 | 09:27 PM
sunset92's Avatar
Car: sunset orange 92
Engine: 5.0
Transmission: t-5
400 sbc
hey is $350 a good price for a used 400 with heads and the only thing it need is a manifold which i already got. he said it consumed a little oil, i asked him if it had bad vbalve seals or if it needs a re ring. its out of a 70 something truck gmc.
Old Feb 11, 2005 | 05:42 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
If you looking for something you can just throw in your car, I'd say forget it. Your taking too much of a risk. Buying any motor and taking the word of the seller is foolish. The price is decent if you are looking for a rebuildable engine, provided you can get take the motor apart and check it out. 400's have area's that are crack prone. If it were me, I'd have the block magnafluxed and have an agreement with the seller that if it's cracked, you get your money back. I've done that with two 400 blocks and wouldn't have bought them if the seller didn't agree.
Old Feb 11, 2005 | 05:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You are basically buying a core. $350 does seem a little high, although they aren't as common as your typical $50 350 cores. It really depends what you want to do with it.
Old Feb 11, 2005 | 06:16 PM
sunset92's Avatar
Engine: 5.0
Transmission: t-5
hey if i could find a 350 core that cheap around here then i would just get one of those and forget the 400
Old Feb 12, 2005 | 02:33 PM
Air_Adam's Avatar
Look around at junkyards and auto traders. Some machine shops keep used shortblocks around too.
Old Feb 12, 2005 | 03:43 PM
sunset92's Avatar
Engine: 5.0
Transmission: t-5
done that already... cheapest i have found around here was like 150 bucks or more...
Old Feb 12, 2005 | 04:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Regardless of whether you're taking a risk or not on the condition of the engine, a stock 400 with stock heads will be an absolute dog performance-wise.
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
