Price of a swap
Old Feb 28, 2005 | 08:45 PM
91rs305tbi's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 700r4??
Price of a swap
i tried looking in the post to see if any one has talked about how much it cost to do a ls1 swap in a 91 rs but i couldnt find it, So if anyone could help me that would be nice
Old Mar 1, 2005 | 02:57 AM
92CamaroLS1's Avatar
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
Well here is a list of pretty much everything for my 92 RS LS1. But do realize: a) I did a lot more than just an ls1 swap, I did the entire drivetrain, brakes, suspension, chassis, steering, mods, ect. b)I probably didnt research as much as I should have before I started and c)I had little patience with buying stuff and sorts so I ended up spending more money than I needed. So overall I think it can be done bare bones at about 5 or 6 k give or take. The most essential parts are engine(obviously), trans if you go that route, have speartech rewire the stock harness, conversion motor mounts and trans crossmember(which I have for sale by the way $215 shipped ), an upgraded fuel pump/system and conversion fuel lines. There are a couple other little things like trans and throttle linkage, but those are the main things to get it running. If you do a search there is a thread about costs of all different types of engine swaps. Hope this helps.
Chris
98 LS1 w/4l60e ....................................3500
*shipping........................................350
10 bolt 3.42 posi rear end...............150
rear end cover.................................40
aluminum driveshaft 1 ....................150 (guy scammed me)
aluminum driveshaft 2.....................100 (didnt get scammed)
Comp Cam.......................................200
Comp 918 springs...........................100
Valve Spring tool..............................40
Chromolly Pushrods........................100
ASP crank and alt. pullies.................220
ASP serpentine belts.......................50
Conversion Tubular Kmember.........450
Conversion Trans Crossmember
and Motor Mounts..........................284 (selling motor mounts)
Conversion Fuel lines/Regulator.....284
Conversion Wiring Harness............450
3700 Midwest stall..................250
155 LPH Fuel Pump.........................100 (wrong size)
255 Granatelli intank Fuel Pump.................150
Kyb AGX adjustable shocks.............400
Eibach prokit lowering springs........285
Brake Proportioning Valve...............48
Head Gaskets..................................75
Head Bolts.......................................46
Crank bolt........................................10
2002 oil pump..................................20
02 timing chain and gears................free
Jba Shortie headers.........................75
Pacesetter Catback..........................325
Custom y-pipe..................................300~
2 Eagle F1's 275 fronts tires.............75
Nittos................................................300
Wet Nos kit .....................................275
15 LB Bottle......................................120
Purge kit...........................................85
A-Arm Bushings................................40 (not even using)
Crossdrilled slotted Rotors...............350
Ceramic Brake Pads.........................100
Rear 4th gen caliprs.........................75
Caliper Mounting plates...................100
Random Bolts/fittings............................100
Cans of paint and underbody...........75
Craftsman Air Compressor................250
Other tools and random things........100
Impact Sockets.............................100
Brake Lines.......................................2.64
Oil/Gear Oil/Additive/Coolant............40
Renting Hoist 3 times........................140
Tubular A-Arms.................................400
Power Rack and Pinon Conversion Steering..........1200
Total Cost = $12,424.64
Old Mar 1, 2005 | 08:34 AM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
92 camaroLS1 is right on target. If done right figure 12 grand. As you can see by his list there many things that should be done to the car to make a well balanced hot rod.
The only reason to do the LS1/3rd gen swap is love for the 3rd gen. A newer F body car can be had for the same price.
Old Mar 2, 2005 | 01:26 PM
91rs305tbi's Avatar
Car: 91 camaro rs
Engine: 305 tbi
ya i love my third gen but as u other third gen owners know, the engines kinda suck
Old Mar 2, 2005 | 02:04 PM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
You can say that again......
I'm looking at about 20 to 25 grand from start to finish. But then again I'm not doing the LS1 swap & my cost estimates include everything from mechanical, wiring, body, to interior.
Old Mar 2, 2005 | 02:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unless somebody comes by and deletes double-posts...
okfoz
Mar 9, 2017 02:35 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
Poncho92
Aug 7, 2015 08:15 PM
