400sb into an 83 Z28???
Old Mar 6, 2005 | 10:07 PM
Twoelouie's Avatar
Car: 1983 Z28,1973 Caprice convertible,1971 Datsun 240Z
Engine: 305CID,400 CID,151 CID
Transmission: R700,400Turbo, 5Spd
I have a spare 400 that I would love to drop into my 83 Z28. I would like to keep the crossfire setup,is that possible?? And, does Holly or anyone else make replacement throttle bodies for my car?? I would assume that going that route that there would be a lot less messing with the computer ??Please advise....
Old Mar 7, 2005 | 12:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's been done. Stock factory 400 heads are terrible.
I don't know of any direct bolt-on replacement TBI's for cross-fire. You might inquire over on the TBI forum.
Old Mar 8, 2005 | 01:37 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
yeah, the heads are horrible (i've got a kinda-stock sbc400 in my car now). i'm lookin to step up to some vortecs (hoping the compression ratio is still within pump gas means). however, this motor is deffinately mroe powerful than my old L03
other than that, the crossfire should bolt right on, but probably wont be able to breathe well enough for the bigger cubes. i have yet to see any bolt-on TB upgrades, but you may be able to get them opened up and larger throttle blades.
Old Mar 8, 2005 | 10:17 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
The swap should be just like a stock replacement and man will it run. As for the crossfire it may be very restrictive but should be ok. I put a 400 in my 83Z many years ago with no mods other then a carb. and it was running high 13's. With some minor tweeking low 13's is no problem. Good luck.
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
