need help on parts for 406 build
Old Mar 28, 2005 | 03:33 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
hey everyone looking for a little help I am getting started on my 406 build and am trying to make sure parts will hold up. not really looking for monster numbers just because of what it is going in. I have an 87 Iroc convertible. anyway boring 400 +.30 and going to 5.7 rods and low compression pistons. also Lunati .480 i/e cam. Heads I have now are just stock 400 heads 76cc, 1.94/1.50 i/e. I will more than likely either switch to Dart Iron eagles or Chevy bowtie heads. Was also thinking about trying out Superflow Aluminum ( http://www.hotrodsusa.com/store/product1949.html )heads from Ebay but need more cash for heads. anyway was just going to use stock crank and possibly a set of gm powdered metal rods. will crank and rods hold up? also was going to use keith black hyperutectics are these an alright choice? I have heard good and bad. Any hlp is definitely appreciated Thanks
Old Mar 28, 2005 | 09:06 AM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Re: need help on parts for 406 build
Save yourself some headaches and go with a speed pro forged piston. Ive turned more than one set of kieth blacks into reese's pieces in the oil pan.
Old Mar 28, 2005 | 10:50 AM
jstoltz's Avatar
what type of hp are you making? what did you use as far as rods and crank? just really want to make sure that motor will hold together. I will more than likely take your advice on pistons. Thanks
Old Mar 28, 2005 | 03:17 PM
Transmission: th350
Im making close to 500 at the crank N/A and about 650 on nitrous. Im running eagle SIR forged rods, and a stock crank. Still a lil worried bout the crank but im sure it will be fine.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
1nastygta
Aug 8, 2015 07:38 PM
