lt1 swap questions
Old May 22, 2005 | 10:49 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
lt1 swap questions
will the lt1 caprice ps hose just drop right in? I just read it in another post but i need a more positive answer. can i use hp hose clamps on rubber high pressure fuel lines??
Old May 22, 2005 | 11:05 PM
TexasLT1's Avatar
Car: '92 RS
I've heard it'll drop in with minor bending
Old May 22, 2005 | 11:09 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
ok kool a few more questions. what throttle cable did you use?? i have a 95 bracket.
Old May 23, 2005 | 12:10 AM
TexasLT1's Avatar
Car: '92 RS
I used a TPI cable I think. it slips into the TB fine, but the plastic clip that holds it into the holder is different, so you kinda just wedge it in there.
Old Jun 25, 2005 | 01:13 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
the lt1 caprice hose was a pain in my @ss. Next time i will just spend the 100$ to buy a custom one.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
