oil preusser sender
Old Jun 7, 2005 | 03:23 AM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
oil pressure sender
ok so i have a mid 70s block and trying it use the oil pressure sender from a 89 305. on the 305 it goes above the oil filter and on the 350 there is no hole with some kind of plug in the way. is it pressed in or threaded. is there a way to get it out or do I have to cone up with some thing new for it?
Old Jun 15, 2005 | 05:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
On my engine, the oil pressure sender was threaded into a hole in the block, just behind the intake, below the distributor. I'm sure you have one in the same place.
jrdturbo
Mar 31, 2016 02:58 PM
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
