TBI Fuel System Question
Old Jun 13, 2005 | 03:44 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Is the stock TBI Fuel Pump's 20 PSI rating regulated by voltage or is it just a flat out different pump than a TPI car's pump?
If regulated by voltage is it the ECM, the Relay, or Other that regulated how much voltage the pump is getting?
Old Jun 13, 2005 | 10:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It is regulated by a pressure regulator that sends the fuel that isn't needed to maintain the pressure back to the pump.
You can use a TPI pump in a TBI system, but stock, the TBI pump would not have adequate pressure to feed a TPI system.
The voltage going to either pump is battery/alternator voltage. It is not controlled except actually sending the power to the pump.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
redmaroz
Aug 16, 2015 11:40 PM
92camaroJoe
Aug 13, 2015 06:07 AM
