350TPI swap: fuel pump?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm swapping out the 305 for a 350 and I was wondering if I need a new fuel pump, and if so what brand/specs do I need? I've never looked at fuel pumps before.
Car: 92 RS CAMARO
as far as the pressure of the fuel pump there is a very informative section on fuel pressure in the faq section(not in the forum part of this web sit, i think it is the main page before you get to the forum). it tells you how to get the most hp from your fuel pressure.
Car: 86 T/A
Engine: HSR 355
How much more gas will my car use if cranking up the pressure? Like 42psi getting 16mpg so 50psi gets...
Thanks for the headsup on that FAQ, I totally forgot about it.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
