V8 swap questions
Old Aug 27, 2005 | 02:51 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
V8 swap questions
I have a 1992 Pontiac Firebird with a 3.1L V6 and a T-5 Transmission. I want to replace the engine with a Chevy V8 create engine. Will a chevy bellhousing (from a Muncie M-21 4 Speed) fit my transmission? Is the transmission input shaft the right length for this swap? Will my hydrolic clutch adapt as well? Any other information you can provide will be appreciated. Please dont send me to other sites to search, because I've already been there. I also read the "V6 to V8 Swap" tech article as well, but I need greater detail.
Thanks.
Old Aug 28, 2005 | 10:55 AM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
As long as the munchie has a 90° SB bellhousing it will work. IM pretty sure your V6 hydraulic clutch wont work unless its modified. The slave will work, but the hydraulic portion ( i know i know hte name, but its slipping my mind right now) that pushes on the throw out bearing will nto work.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
